dashboard AR 147
dashboard AR 147
I was forced to replace the instrument panel. The new dashboard has VDC, as I do not have . I noticed from the example CAN SETUP / PROXI Stille, 159 it commands the dashboard I do not have vdc, asr. This function can set the type of ABS system in the vehicle - ABS/ASR/VDC/TC. This function can not be the 147th for Alfa? But I do not mind so much. And I'm sorry caz scriptures google translator. Thank you and Good luck Jans
