First test multiecuscan 1.3 ECU Delphi Stilo 1.8 16v
aperdigao
Post by aperdigao »
Hello everyone ..
Yesterday I tested the new version of multiecuscan 1.3 and found some "problems":
Unable to access ECU (DELPHI MT25E) my Stilo 1.8 16v (Brazil), despite that the specification should be the FIAT Brazil (DELPHI - HFSI 2.3).
ISO without error, correct readings of all available sensors. Graphics ok.
When I test the actuators in a specific FAN Speed ​​1st and 2nd FAN Speed​​, auditioned for the 1st FAN Speed ​​claims to be executed but the FAN does not work in the car. For 2nd FAN Speed ​​test claims to be executed but the FAN (propeller) turned slowly as equal or worse than the 1st FAN speed in real operation.
To make sure I left the car running until it reaches the activation temperature 1st FAN Speed ​​(approximately 98 º C), and it worked normally.
Doing the same test for speed FAN 2nd, start the AC and FAN speed 2nd worked correctly.
Thus, I would just tell you this little "bug" that might help you in the next version already.
Thank you
Re: First test multiecuscan 1.3 ECU Delphi Stilo 1.8 16v
If the ISO code is accepted by the program without error when you connect by selecting DELPHI MT25E then this ECU should be MT25. They probably use different labelling for the Brazilian market.
aperdigao
Post by aperdigao »
Thanks for the reply Yani ..
I'll continue testing version, and I hope that my story will help ....
Thank you ...
misaeru
Post by misaeru »
hello, can not connect on fiat stilo 1.8 8v Brazilian model, but I can do almost nothing. I have the registered version and cable ELM 327 chines. When do the initial scan engine he accuse ISO unknown or unsupported. Does anyone know how to solve?
