high latency KKL Vag Com 409.1
Posted: 23 Jan 2013, 19:27
by freeman_81
Hello! Sorry, I do not know much English.
The problem is as follows ... ECU is connected to, but after 5-20 seconds disconnected gives "connection error" and "high latency". But I have time to see the error.
Adapter KKL Vag Com 409.1 Chinese chip CH340T, the last driver, only they do not have the settings for the delay, as the drivers of other chips.
http://8.orsha.schools.by/data/8.orsha/library/2.jpg
Here's a photo of the test adapter in the program.
http://8.orsha.schools.by/data/8.orsha/library/1.jpg
Program settings - "high latency mode" and "KP2000 timings", do not help.
how to fix the delay? waiting for your help. THANKS
Re: high latency KKL Vag Com 409.1
Posted: 23 Jan 2013, 19:47
There were times in the old versions of multiecuscan (3.5) times connectivity issues
with the KKL Interface
but I thought it was over,
Is your battery charged?
Try it once with another PC!
Depending on which car you have, you can also try the free version of MES.
Posted: 23 Jan 2013, 22:24
by freeman_81
Alfaeddy wrote:Hello
fiat tempra 93. bosch monomotronic MA 1.7
car battery was discharged. Took home the charge. I tried to connect the KKL Vag Com 409.1 at home on another computer (xp SP3), connecting only + 12v. (16-pin) and - (4-pin) to the battery. The result is the same. latency did not change.Here I do not know why when changing latency in the program, the test result is the same.?
Posted: 24 Jan 2013, 09:43
Hello Freeman_81
Do you use the registered version of Multiecuscan?
If so
I suspect a connection problem of software
and I advise you to write directly and Yani times
to describe your case
Posted: 01 Feb 2013, 09:13
by freeman_81
Hello!
Yani can pay attention to my problem? I know that there is an entire branch dedicated to high latency, the fact is that I bought a second KKL Vag com adapter, only the FTDI chip (ft232rl). Change the delay from 16 - 1 ms. It became possible to look better options 1-5 minutes, and again goes into the main menu.
Yes, a laptop and have a weak CPU 1.65 GHz, 4 GB. ECU monomotronic MA 1.7 (Fiat Tempra, 93).
Is it still, what to do? Thank you
