Airbag connector FIAT BRAVA
Posted: 11 Jan 2013, 17:15
Does anyone know where exactly is the airbag connector in Fiat Brava.
I found information that says that it should be under the glovebox, so I found a connector which is with black colour (black lid or cap) and has 3 wires with colours- green, black, white-brown.
I did connect my Vag-Com cable but nothing happened, even the blue light did not came on. After that I supplied with voltage the vag-com cable from the lighter of the car, I tried to connect to the airbag Ecu but I could not.
After that I found information that there are two 3 pin connectors- one for the airconditioner and other for airbag.
May be I did not see the connector or maybe I have not set up properly my settings of the computer. With the same cable and settings I connect with no problem to the main ecu of the car.
Please note that I do not know the version of the vag-com cable I use .
What is my mistake, what I am not doing right. Please help.
Thank you in advance !
The car is BRAVA 1,6 year:1999 SX
Regards,
Alex
Regards,
Alex
