Panda security code "failed to execute"
Posted: 24 Nov 2012, 09:57
by amsgoran
Hi I am using reg FES 3.3 on Panda 2006 1.2 8v
Tried to code a remote key fob that used to work ... but when I enter security code from key card I get failed to execute window . If I enter incorrect code fes tells me its wrong code and ecu will lock itself after 3 wrong codes blabla..... So I guess the Code is correct because I get that error screen only entering code from card that came with the car . Is this a bug ?
P.S. Previously used fes to code remotes to many fiat cars so elm,fes,me work(ed) without any issue.
Thanks .
Re: Panda security code "failed to execute"
Posted: 25 Nov 2012, 18:09
by alfa156sarajevo
I thing it is a bug in MES software!
Did have similar problem on Punto from 2001 and I just could not program remote controle.
On my Alfa 147 remote control programming is working just fine…
Posted: 01 Sep 2013, 09:56
by rolandp
Hallo,
I have also an panda cross build 2006 with Siemens Body and the software version 1.4 let me not work to prg an new remote control and show me unknown mistake...and breaks
I sent a view picture today to the support.
This ist an bug. becaus the alfOPD software works with my car code....
Roland
Posted: 02 Sep 2013, 21:45
by alfa156sarajevo
rolandp wrote:Hallo,
Roland
Yep with AlfaOBD it works! ;)
Posted: 07 Sep 2013, 10:49
by rolandp
No reply from for my support email over 1 week !
I bought the software for prg. and fix problems for cars that are 6 years or older and the version 1.4 (2013) doesn´t work !
It´s a shame for a product that problems are not fixed !
Roland with original bought software !
Posted: 08 Sep 2013, 10:32
Have you tried Version 1.6 (current version) of MultiECUScan?
If not then I suggest you try this version whilst waiting for a support reply.
It is important to take advantage of all free updates whenever they appear. This will ensure that you have the latest version when your free update period come to an end.
Posted: 08 Sep 2013, 17:58
by rolandp
I have an licence for max. ver. 1.4 und the car is 2006, so I must buy a new licence...
I won´t pay again for a funtion that is offerd with my version and how should I know that the version 1.6 will work ?
I understand that problems in software are normal, but not with cars that 7 years old.
Roland
Posted: 09 Sep 2013, 12:10
rolandp wrote:I have an licence for max. ver. 1.4 und the car is 2006, so I must buy a new licence...
Roland
Please see here: http://www.multiecuscan.net/Register.aspx
It clearly states:
- The License is valid for CURRENT VERSION of the multiecuscan software.
- The License is also valid for 1-YEAR FREE UPDATES of the multiecuscan software. After 1 year you can continue to use the software forever, but you will not be able to update it.
You have V1.4 which was released in 02/05/2013 - MULTIECUSCAN 1.4
This means you can continue to upgrade versions until a year after you bought V1.4 so until at least 01/02/2014.
Posted: 11 Sep 2013, 15:34
by rolandp
Hallo,
my version is updated to 1.4 and I bought it mai 2012 so ver 1.4 ist the max. that I can use.
The support Mr. Yanislav Karagyozov has written me...
" We have a few reports about problems with remote control programming on Siemens body computers (which is the body in Panda). It seems that programming of remote controls is only possible when you also program the keys at the same time. However, we don’t want to include key programming functions in Multiecuscan (for safety reasons).
Unfortunately we do not have solution about this problem yet. "
So the support answer after 9 days waiting is ok, the bug for siemens body is still inside...but the software is with this problem anyway usefull and good, and no software is bug free...maybe a newer release will fix the bug...and I will need it in the furture
Roland
