Min/Max Parameters values
TribesMan
Post by TribesMan »
Is it possible to add min/max sensor values (next to the actual sensor values) under parameters section?
I really miss this from Alfadiag, it helps a lot if you are just trying to log some absolute max values, for instance max boost pressure, max air flow, max fuel pressure while driving.
It would be faster and clearer than using Graph/Export CSV and then loading it in Excel.
This min/max values can be also added in Graph section, where there is a list of logged parameters.
What do you think is that possible?
Re: Min/Max Parameters values
I have already inculed similar feature in the next version. I will probably release it at the end of month.
TribesMan
Post by TribesMan »
Great! That will make it even better. :)
