Using FES on a mates Alfa GT 1.9 JTDM.
One of the parameters available when the engine is running is Engine ECU, which when ticked = 'Programmed'.
Can anyone tell me what this supposed to imply ? All Engine ECU's are Programmed.
Engine ECU = 'Programmed'
- AlfaGT.jpg (122.56 KiB) Viewed 2668 times
Re: Engine ECU = 'Programmed'
I guess this indicates that the ECU is not virgin, i.e. it is married to the immo system.
The term virgin is very commonly used when speaking about ECUs, so I think it would be better to use that expression in MES.
