Hi All,
I have a Stilo and have the odeometer flashing, and the climate control doesn't work properly. The air conditioning button sometimes activates the climate control and the snoiwflake comes up, sometimes it doesn't.
I connected and tried a PROXI Alignment, the dashboard and body aligned succesfully, but the climate control failed everytime,. So I still have a flashing dashboard and the air con doesnt work. Is there anything i should check for???
Many Thanks for any help you can provide.
Wayne
Proxi Alignment problem with stilo climate control
Re: Proxi Alignment problem with stilo climate control
From my experience I got to the next conclusions:
- First of all try to connect to all modules (body, doors, dashboard...) on your Stilo and delete all errors (which you can delete).
- Second thing, try to do proxy with all doors and windows closed and everything should be connected to the system (radio, climate, window switches on the doors...).
- Third thing, if does not work today, try to do it tomorrow, or day after tomorrow...
Sometimes is just working fine and sometimes it does not work at all!
In the past few days I tried to do proxy on few cars (Stilo JTD and Alfa JTD). With Stilo everything was fine but with Alfa not. So I did try the next day and it was working normally, like nothing happened day before.
And one more thing if proxy does not work after 4-5 tries just leave it for next day.
Once I did tried proxy for a 10-15 times in a row and suddenly everything went on.
Climate was on, radio was on... I could not just turn it off... Only when I turn off a car then everything was off. So I disconnected battery for a 10-15 minutes and everything was just fine. Just be careful!
