Recalibrate injectors.
Posted: 25 Mar 2012, 20:04
by Benzina159
Hi all, ive been told that i might have to re calibrate my injectors using FES because of a problem i am having on my car. Now ive seen the function to re calibrate the injectors are there but i have no clue what codes i should put in??? anybody know how i should do this?
The car in question is a 2006 Alfa Romeo 147 1.9JTDM
Re: Recalibrate injectors.
Posted: 26 Mar 2012, 09:30
You need to check the injector codes displayed in Multiecuscan with the codes on the actual injectors. They should match.
From the help:
Injector classification with IMA method (Injector Quantity Adjustment) is a procedure that aims at improving motoring performance and the emissions by combining the structural characteristic of each injector with the control software strategy inside the engine control unit.
The characteristics of each injector are identified by a series of 9 alphanumeric characters stamped on the injector body while still in the BOSCH Factory.
NOTE: Injector classification can only be performed with the engine off.
WARNING: When finished entering the code ALWAYS check the value reported in Parameters section. If the code is entered/stored incorrectly, repeat the procedure.
