Service Intervall - Fiat Bravo '07 1.9 Mjet 16V
Posted: 20 Mar 2012, 07:32
by GiZam
Good Morning,
i am from Germany and a newbie with the FiatECUS.
I received a full version of FiatECUS and i got a compatible connector for my Fiat Bravo '07. I have no problems to connect to the car.
What I want to know is, what exactly i have to reset in the Service menue.
I made a full service check on my car.
Now i want to reset the km and disable the oil change light because i changed the oil.
Does someone know what exactly has to be done in the menue?
THX for help!
Re: Service Intervall - Fiat Bravo '07 1.9 Mjet 16V
Posted: 20 Mar 2012, 11:30
To reset the oil light connect to the Engine module/service and then go to the Adjustments Tab (F7). The first item on this is your Oil Change Reset.
To reset the service then connect to the Service module/service. The Parameters Tab (F4) will show you the service data. The Adjustments Tab (F7) will allow you to update the service information and do a service reset.
Hope this helps
Posted: 20 Mar 2012, 11:37
by GiZam
Thank you! I will check it and reply if it worked!
