connecting to ecu
dinky
connecting to ecu
Post by dinky »
hello
can I connect with the free version into the module engine
because the only connection that I can make is into the airbag module
or is the connection to the ecu in the engine module on another com port because when i connect it says no ecu responce check comport
I have connected all the possible com ports but none works
thanks
Re: connecting to ecu
And you have which car? Model? Engine? Year? :roll:
