Q: how ADJ and so on?
fraguzz
Post by fraguzz »
hello
i have a fiat panda 1.3 mjet "Marelli 6JF EOBD Diesel Injection (1.3)"
you type ADJ.. what does that cover?
-that i can change the data?
-the maps are visible and have things like rpm, tps, and so on?
ADJ on the stearing rack.. can i ajust the senservaty like the button on the 100hp (sport button) does?
Re: Q: how ADJ and so on?
INFO - DTC - PRM - ACT - ADJ = they are all shortcuts.
INFO means information
DTC means detect trouble codes
PRM means parameters
ADJ means adjustments
and it goes on and on…
See the photo...
FES info screen - details.JPG (98.33 KiB) Viewed 3520 times
fraguzz
Post by fraguzz »
yes thanks but that was not the Q
can i ajust things when it says ajustment?
Juggers2k
Post by Juggers2k »
fraguzz wrote:yes thanks but that was not the Q
Download the software, and connect to the vehicle and module you want to cover in simulation mode (CTRL+F10).
(you don't need to have the interface cables or a software license to view everything in sim mode).
Then go to the Adjustment tab - it will show you the adjustments available on that module.
