Croma EDC16/CF4 Water in Fuel Light & Oddometer
Posted: 29 Jan 2010, 17:04
I've been testing V1.6 and may have found any issue with the water in fuel light test.
I'm sure the first time I tried it the light illuminated/blinked on the dash. However on subsequent testing nothing happened. The bulb is not broken as the light comes on and goes out with the normal ignition on cluster check.
Also the oddometer figure reads a little over 7000km but I've actually got nearly 36000 miles on the dash oddometer. Not sure what the relationship is between engine ECU oddometer and real dash oddometer.
