ELM327+multiecuscan3.3
Posted: 30 Jan 2012, 22:08
I have a problem with the interface ELM v1.3 does not work with version 3.3 multiecuscan recorded
http://cgi.ebay.fr/ws/eBayISAPI.dll?Vie ... OC:FR:1123
following set of parameters and serial port speed 38400 baud, he said at the outset: the interface IS compatible with ELM327 1.4!, Should connect Properly modules with all modules.
connect to the ecu: ELM327 -> ECU connection failed. check your cable and your serial port configuration.
I do not understand why? Is that the interface is not compatible with multiecuscan?
I have a Fiat Doblo 1.3 Multijet 85 hp V16, 2007
thank you for helping me
