Airbag Connection problem
gerryd
Post by gerryd »
Hi guys.. I have a Alfa 147 with the airbag light permanently on, I want to connect using FEC and my ELM327, but when hitting connect I get a direct message saying you need K-Line or Vag-com for this function.
now.. is this true? I thought I could use ELM device for all the ECU functions with FEC? is there a different method? My cable can connect to anything else on the car, Body, ABS, Engine, Gearbox, etc. but Airbag is a no no :(
Juggers2k
Re: Airbag Connection problem
Post by Juggers2k »
Yes, it's true. From the supported vehicles list:
SIEMENS MY99 Airbag (2F-2P-2L-2T-I) |INFO|DTC|PRM|ACT| KL 3 OBDKey 3 A2
No mention of ELM there.
gerryd
Post by gerryd »
thanks.. where did you get that from? I want to see that list and see what else I can find..
wonder why they then say you need ELM OR vag com OR obdkey :(
Juggers2k
Post by Juggers2k »
gerryd wrote:thanks.. where did you get that from? I want to see that list and see what else I can find..
Some modules can be accessed with both the ELM and the KKL, others require specific features of one lead that are not supported by the other.
From memory the OBDKey interface supports everything, but it's more expensive than buying an ELM and a KKL, so swings and roundabouts...
gerryd
Post by gerryd »
thanks bro, now I am off to get me a damn vag com as well.. already have the ELM.
