HI Yani and hi to all.i had the fes 3.3 registered and the connector cables and now i need the elm for service reset and other jobs.Where can i buy one so do not have any problems with elm versions...or faulty elm...or connections?JUST WANT TO BUY THE CORRECT ONE..
THANKS. C.KOULOUNDIS
WHICH ELM VERSION?AND WHERE TO BUY?
Re: WHICH ELM VERSION?AND WHERE TO BUY?
The Gendan ELMs work fine with FES and do not have the resistor problem that plagues the cheap clones.
If you're in the UK you can buy from www.gendan.co.uk
If you're anywhere else in the EU, they sell under the username "sitereams" on ebay.
Hey,
also this Interface from ELECTRONIC-FUCHS works very good....no problems with CAN! (He added resistor and capacitor to CANBUS ...) New Layout! It is modifided for multiecuscan!
http://www.electronic-fuchs.de/shop/art ... D1000-7%26
Regards
Regards
