Stilo: automatic light -body don't see switch in on position
Posted: 15 Jan 2012, 12:06
after assembly rain sensor and new manipulator with switch auto light this feature don't work.
of course rain sensor work perfect but auto light not.
when i connect to body and look on parameter autolight switch is always off. I check wires, all is ok, ground is set on "i" connector in m1 on 2 pin.
i found in fes 3.3 feature "enable auto light" in proxy procedure, but after proxy body still don't see switch in on position
body use the same way (7 pin on m1) to response rain and light and I think, the main problem is on read signal from switch
any ideas to enable in body read position autolight switch?
cheers
stilo 1.9 jtd dynamic 2002
cheers
