Hi, I have succesfully connected to my car Bravo 1.6 year ´99, but I can only do so with 1.41 version, with 1.5 not connect. And with 1.41 version only read and erase error codes, the actuators option or sensor read option don`t work.
I wish i could to use all the functions of the program, do you know if in the next version will be?
and why in the latest version does not work?
Thanks Yani.
IAW49F problems
Re: IAW49F problems
Thanks for the info. I'll see what I can do about this, and will make a fix for the next version.
Re: IAW49F problems
In my Bravo 1.6 1998 works fine version 1.5 - I tried some actuators test and was OK. Identification on my ECU is IAW49FHW001
Maybe some KKL cables works with some not...
Re: IAW49F problems
My Bravo is 1.6 1999 CF2 and the ECU is IAW49FH002, perhaps that is the reason of failure when i try to use the other functions, Yani says anyway that it fixed in 1.6 versión, my thanks to Yani.klimekkk wrote:In my Bravo 1.6 1998 works fine version 1.5 - I tried some actuators test and was OK. Identification on my ECU is IAW49FHW001
Re: IAW49F problems
Please give me feedback whether v1.6 works properly on IAW49F or not.
Re: IAW49F problems
Hi Yani,
Just checked version 1,6 on my engine ECU. Almost all works perfect. I found only possible 3 bugs:
1) Parameters->Odometer: (not very important for me) program shows 79926km while on dashboard stays 118595km
2) Parameters->A/C ON and A/C Compressor: program shows OFF with aircon off and on. A/C in my car works fine. I performed test on A/C clutch relay - when test starts i can hear that cluch is working.
3) Actuators->Tachmeter test: in description stays that tacho will show approx 1500 rpm - during this test my tacho shows approx 1900 rpm. I checked also tacho with engine ON and program shows the same engine speed as was on dashboard.
4) Graph: - not possible to start graph - i don't know what could be checked with this function. Maybe is not supported with this ECU...
Some printscreans:
info page
http://img30.imageshack.us/img30/4083/ecuscan1.jpg
Parameters with engine on idle:
http://img695.imageshack.us/img695/5575/ecuscan2.jpg
http://img691.imageshack.us/img691/927/ecuscan3.jpg
http://img685.imageshack.us/img685/2429/ecuscan4.jpg
Many thanks for this amazing soft!
Some printscreans:
info page
Re: IAW49F problems
Re: IAW49F problems
Hi, well i just try the 1.6 version, and aparently working with the ecu iaw49f, the errors can erase, the parameters can be read, and the actuators works but not well, i mean when i try tu probe injectors, coils, evap solenoid, the fuel pump starts and it should not work, i connected the car with Bosch machine in the friend`s shop and the pump don´t work when probe this actuators, because if the pump is working when i test injectors fuel would enter to cilinders, when i probe with friend`s machine i heard clicking the injectors, and when probe the coils heard clicking the spark plugs.yani wrote:Hi,
The only problem is the Airbag, i try to connect to Airbag in Bravo 1.6 16v year ´99 but does not connect with him, i probe all options breed to this car in multiecuscan 1.6, but does not work. The car is post first modification, CF2, according to workshop manual. I need reading airbag error if you include this car in next version i would be very grateful.
Thanks yani.
Re: IAW49F problems
In my bravo also can't connect to airbag, today i checked what ECU is there. I can't find any brand name on it - have only number: 464793640
There is a picture of it: http://img407.imageshack.us/img407/9651/dscf3928.jpg
Re: IAW49F problems
I searched the kinds of airbag in fiat bravo, and are two types: Breed and Breed MY 97, may be Breed the type of our cars airbag.
I don´t know what it is 2F, 2L, 2S, S when i try to select the type of airbag but does not work either.
Visit this link and you find information of our cars components:
http://www.sun-diagnostics.com/products ... Fiat3x.htm
