Punto 2000 compatability
Posted: 05 Jan 2012, 23:53
by daniel.b
Hi I have just bought a 2000 Punto 1.2 8V. I am getting the incorrect ISO code error when I try to access the "....EOBD injection" system. If I ignore the error then I can see some of the parameters but I cannot access any of the other systems. I have read that the "early" mk2 Punto's are incompatible with Multiecuscan but the thread was back in 2010 I just wondered if it had been updated to accommodate my car and I'm just missing something.
Thanks,
Dan
Re: Punto 2000 compatability
Posted: 08 Jan 2012, 18:08
by Juggers2k
Which model from the list are you choosing when you try to connect?
Posted: 19 Jan 2012, 18:17
by daniel.b
Hi, thanks for the reply.
I have tried both the "PUNTO '99 1.2 8V" and the "PUNTO '03 1.2 8V" and on both when I can access "MAGNETI MARELLI IAW 4AF/4EF/59F/5AF EOBD Injection" which appears on both of the vehicles under the "ENGINE" section and I get the ISO code error on both.
Thanks,
Dan
Posted: 20 Jan 2012, 10:34
by Juggers2k
If you run a scan, does it report your engine management controller correctly?
