Alfa 159JTD 2.4 20V Airbag
Posted: 30 Dec 2011, 23:40
by rat156
Hi All,
I can't seem to connect to the airbag computer on the car.
I'm using an ELM 1.4 Bluetooth based device.
Any ideas?
Cheers
Stuart
Re: Alfa 159JTD 2.4 20V Airbag
Posted: 31 Dec 2011, 10:04
Your BT ELM interface can not handle CAN protocols.
Many BT v1.4 interface have the same construction as here in this forum
described v1.5 USB interface
You have to open the interface and remove the resistor R04 on the board.
It is safe to the CAN problem, because you sure with your BT with the ELM
ECU will get a connection.
