INVAILD Ecu Iso number BOSCH ABS ECU Connect
Tomasman
Post by Tomasman »
Hy all!
My error:
I'm modify the VAG-COM KKL inter face! Insert Switch to Switch!
Pin7 Switch Pin1
Pin7 Switch Pin3
Pin7 Switch Pin7
Pin7 Switch Pin9
The Pin7 switch Pin7 (K-line to Pin7 Engie/gearbox) ECU connection work carefully! Magnetic marelli connect
The Pin7 switch Pin1 or Pin3 or pin9 connecting message: INVAILD ISO NUMBER
Actuator test dosen't work, but some paremeters and reading!
What is a problem? The cabel dont work good? Please help for me
Re: INVAILD Ecu Iso number BOSCH ABS ECU Connect
What is the ISO number shown in the program?
Tomasman
Post by Tomasman »
Tomasman
Post by Tomasman »
yani wrote:What is the ISO number shown in the program?
Hy Yani!
Thanks for help!
The ABS connecting try this day again and working carefully! I'm connect the BOSCH ABS VDC, and work grate!
But a airbag system connecting not good! Show messege:
INVALID ISO CODE
Ecu ISo number: A7 86 91 19 2C
Fiat drawing number: 00 46 75 61 17
My car making date 2001.11.00
This is a picture , show error message:
[img][url=http://kepfeltoltes.hu/view/100121/airb ... es.hu_.jpg][/img]
Thanks for help!
Tomasman
Post by Tomasman »
Hy again!
The problem: My car makeing date 2001.11.01 This car airbag system Simemens MY97 ? The face lift 147 inside Siemens MY99? Thanks
Thanks for help!
Your Airbag is ALLIED MY 97 which is not supported in version 1.5 of the program. It will be supported in version 1.6 which will be available at the end of this week.
Tomasman
Post by Tomasman »
Hy Yani!
Thanks for reply! I'am wating for next 1.6 version!
Thanks for help and all! And thanks and gratulations for HUNGARIAN alfa funs!!!!
