problem with fes 2.6.0 fiat stilo 16v 1.9jtd mjt
Posted: 12 Dec 2011, 16:30
by mattecabras
(use google translator)
Hello, my name is Matt, I'm Italian, I have a problem with that multiecuscan risesco to solve.
I interface ELM327 1.4a, when I connect I can only go on the engine control unit, does not detect other stations, says com port error, eobd ...
when I do the search the ECU is just that, how to solve? I'm going crazy ...
I also tried to get into the car of my dad (stylus 1.6 16v) and here is only the engine-control unit.
help
ciao, mi chiamo matteo, ho il seguente problema,
quando mi connetto allla mia fiat stilo 1.9 jtd 16v fes trova solo la centralina motore, se clicco in qualche altra centralina mi da errore porta com, eobd
Re: problem with fes 2.6.0 fiat stilo 16v 1.9jtd mjt
Posted: 12 Dec 2011, 16:45
by Juggers2k
Ok, firstly why are you still using v2.6? - update to version 3.3, which has several bugfixes and more vehicle support.
(If you are using an illegally cracked licensed version of 2.6, then frankly you should not expect any support).
Once you are on v3.3, if you are not registered, you will only be able to access:
- Engine
- ABS (with adaptor 1)
- Airbag (with adaptor 2)
- Power Steering (with adaptor 1)
- Service Reset
- CAN info
The airbag will not work with an ELM327 interface though - you need to us the KKL interface for that.
So are you using the right adaptor cable when you try to connect to other systems?
Can you connect to CAN info and Service Reset?
Posted: 12 Dec 2011, 17:42
by mattecabras
Hello!
, my friend lent me this cable with this software, I honestly do not know if it is original or the crak preogramma.
I have to enter the computer reimbursement Marelli, (if that's the name) because I have to enable the antitheft function (blinker)
that is, when I close and open the car I want to turn on the arrows and you hear the beep beep ..
my car has always done, 2 Settin ago I left the stereo on all night (forgot) and now stop flashing ..
I read on the forum stiloclub which is a function to be enabled ...
Posted: 13 Dec 2011, 09:51
by Juggers2k
I believe that function would be on the "Marelli MF Body Computer", which is only available with the licensed version of the software.
It would be worth running a module scan with the free version of 3.3 to check that that specific module responds on your car.
Posted: 13 Dec 2011, 13:48
by mattecabras
hello, after much research on the internet I removed the 2 resistances at random .. R04 / R14 and now it works !!!!!
cabbage but now I have another problem that I did not know .. set to ask me what I want the code of the code card that I did not! when I bought the car they gave me only 2 keys and all.
Perhaps here is not okay to talk about, but if you know how can I do? sell it??
Posted: 14 Dec 2011, 10:01
by Juggers2k
If you don't have the security code card for the car, if you can prove you own the car, a Fiat dealer should be able to replace it for you.
Posted: 14 Dec 2011, 16:54
by mattecabras
Hello, today I went to the fiat, it costs 48 euros !!!!!!!!!!!!!!!!!!!!!!!!!!!!! it is dear! But I took it, put the code with fes, and I solved the problem !!!!!!!
thanks anyway to everyone who responded.
matteo
