Bosch MS6.3 Diagnostic possible ?
Posted: 14 Jan 2010, 12:11
by FreddyC
Hi.
thanks for your very good work. It´s posible to add the BOSCH MS6.3 ECU in the software ( For Iveco Daily 2,8JTD Power / Building 2003 ) ?
many thanks in advance for reply
greetz Freddy
Re: Bosch MS6.3 Diagnostic possible ?
Posted: 22 Jan 2010, 19:12
by FreddyC
Hi Friends,
i have now tested to make a connection to my MS6.3 ECU.. It works and i can read out all the failure from the ECU. Unfortunally it´s not possible to see any other dates. So i hope that YANI can add the MS6.3 ECU to the next release from multiecuscan.
Thsi is the only software that i tested, that going online to the ecu. All other software doesn´t connect to ecu with the kkl cable. ( I tested Modiag, Fastnet, VAG Com ( ok..thats only for VAG i know t.. ) scantool, OBD Scantech, But only multiecuscan connect !!! So i hope that you make a very good job and add the MS6.3.... ( I think a lot of people can need it... )
Greetz Freddy
Posted: 22 Jun 2011, 06:41
by nuki_tsw
I've tried with a newer Iveco with EDC16 and Multiecuscan has communicated with ECU via VAG K-L but the protocol wasn't compatibile. I could just remove faults, but their description was not correct. I hope the next version of Multiecuscan would communicate with Iveco Daily with MS6.3 and EDC 16. I would be very gratefull for this.
Regards
Marcin, Wieliczka, Poland
tel: +48 888703196
Posted: 19 Jul 2011, 06:46
by mojpeugeot
nuki_tsw, Which car did you select when you connect to EDC16 inside iveco ?
br
