I have the obd2 cable (USB Interface). When installing the driver, the driver is installed as USB and not as COM port (USB Serial port) as on your guide.
I have tried installing it few times and tried to change some setting, but no matter what I did it was always the same.
In the past I installed an older version with the same cable, same operation system (Windows XP) on the same coputer and it worked fine.
Can you please advise?
Connect problems
Re: Connect problems
What cable type do you have?vova99 wrote:I have the obd2 cable (USB Interface). When installing the driver, the driver is installed as USB and not as COM port (USB Serial port) as on your guide.
ELM327, KKL, OBDKey or something else?
