No connection to airbagsystem alfa 156 1.8 TS My 97
Posted: 06 Oct 2011, 11:21
by palamp
Hello i have try fiat ecu scan but can not connect to airbag ecu, i have a modified KKL cable which i can connect to ABS,Motronic but airbag doesnt work.
I have changed the airbag ecu why i have thinking that the ecu is fraud but doesent help, the same problem fiat ecu scan cannot connect to airbagsystem :(
can you please help?
Re: No connection to airbagsystem alfa 156 1.8 TS My 97
Posted: 11 Oct 2011, 09:00
by euroscan
- try to use software KWP71Diag.
Posted: 11 Oct 2011, 15:45
by palamp
no the same isuses
Init started
error rcv wait timeout
Init Ready
No KeyBytes; Init not OK
Init started
Init Ready
I have try on the different ECU also FIAT Marea ECU with the Nr: 46409123 and alfa 156 ecu 60656767 ist not possible to connect
Posted: 15 Oct 2011, 10:44
by palamp
Update:
I have try to connect to the Airbag ECU from TRW with the Nr: 60663943 from alfa 156 MY 2000 it dosen't work, fiat ecu scan can not connecting to this ECU.....
Last Fiat ECU SCAN version 3.2 ;)
regards.....
Posted: 15 Oct 2011, 12:15
by yani
It has been discussed before!
This airbag module is not supported.
Posted: 15 Oct 2011, 13:56
by palamp
But in your list is a MY97 marked as supported and TRW also in the list? It will be great if you can create a list of Airbag ECU which Fiat Ecu Scan support.....The ECU which i last try to connect was a from car MY00 :?: :!:
This ECUs are used different Protocol as KWP2000?
