Hi!
If i buy multiecuscan, i need to know the default parameters of my cars?
For example, if i read "Lambda = 100"
I don't know if the car work wrong or not... i don't know if lambda must be 100 or 1 or 1.000 or in a range of values...
Is there a manual, a guide please??? In particular for alfa 166 3.0v6
Thank you !!! and sorry for my bad english.
Daniele
how can i know if the parameters are correct?
Re: how can i know if the parameters are correct?
- If you have the proper car do it all the measurement parameters of the car and mark it as correct.
- this will be your database in case of failure of the car.
...And if he has some problems with any sensor and needs to compare his/her measurements to the measurements of the proper car? Then what?euroscan wrote:- If you have the proper car do it all the measurement parameters of the car and mark it as correct.
Ciao Amiko,per prima vedi sulla tabella errori-poi se non ci sono errori bisogna capire se c'è un sensore starato,la tabella parametri di valori non sempre sono messi a disposizione,per sapere i valori poi bisogna entrare nella riparazione e cercassi i vari manuali di riparazioneamiko wrote:...And if he has some problems with any sensor and needs to compare his/her measurements to the measurements of the proper car? Then what?euroscan wrote:- If you have the proper car do it all the measurement parameters of the car and mark it as correct.
saluti
Thank you for your reply, but I do not understand Italian, amico!Aron96 wrote:Ciao Amiko,per prima vedi sulla tabella errori-poi se non ci sono errori bisogna capire se c'è un sensore starato,la tabella parametri di valori non sempre sono messi a disposizione,per sapere i valori poi bisogna entrare nella riparazione e cercassi i vari manuali di riparazioneamiko wrote:...And if he has some problems with any sensor and needs to compare his/her measurements to the measurements of the proper car? Then what?euroscan wrote:- If you have the proper car do it all the measurement parameters of the car and mark it as correct.
saluti
I love Italian, but I can not understand it
Amiko Hello, you first see Table Silla ERROR-then if we do not need to understand if there are errors UN sensor not calibrated, the parameters of Table Values are not Always put a provision, then you have to know the values in the repair and tried to enter the various repair manuals
greetings translated with google
I tried to translate your words in GOOGLE before, but it is a very BAD translationAron96 wrote:Amiko Hello, you first see Table Silla ERROR-then if we do not need to understand if there are errors UN sensor not calibrated, the parameters of Table Values are not Always put a provision, then you have to know the values in the repair and tried to enter the various repair manuals
I still do not understand the point of your text.
What do you mean saying "Table Silla ERROR"?
when you walk on multiecuscan you connect to the engine control unit, then you can see the parameters entering the unit and also errors of errors and see if there are errors
OK. I understand.
BUT where can I find the best values for MAF in case if I want to compare my MAF sendings?
Hello Friend, unfortunately I do not understand you mean Aqualite parameter with MAF, if you can give me more accurate information you possibly can to pass some value detail. But as I said the word MAF does not mean anything to me.
greetings
greetings
