Thanks for the free software it looks great, just a couple of questions if you don't mind
(1) Will it work on a Fiat Ducato 2.8 JTD 2004/5 model
(2) You suggest that Any cheap VagCom KKL cable will work!!!, I have seen this one on eBay
"VAG-COM 409.1 KKL USB CABLE FOR VW AUDI SEAT SKODA GOLF" Item number: 120513316122
But it states:- Please note if your car has can-bus fitted (late 03 onwards) this interface will not work!
Will it work or do i need another type of cable
(3) You state in your How To Use setup of the USB ports and cable "Note that for PL2303 USB serial port you will need to modify some registry settings in order to make it support 10400" how do i find if i have a PL2303 USB serial port and if i have how do i find what registry settings need modifying,
I would really appreciate your help
ASDA
