selespeed
wilco1v
selespeed
Post by wilco1v »
punto 2003 selespeed read with fes and with bosch kts
fault code (kts P1750 solenoide gearbox 1-2/3-4...) fes p1750 solenoide valve selection
was the same ,only bosch kts came up with extra freeze frame data
temp -rpm-speed-pressure and a few other data
like to see olso in fes ????
try tomorrow to collect printscreen from kts tester,have printscreen@ home
hydraulic prssure 41000kpa
4416 rpm
25km/u
tranmissie oli temp 38,4 celcius
ecu 12,6 volt
and examiner same freeze frame as kts only extra info :event = 61x
update 08022012
we placed used robotic unit(panda) and stil not seen again
12 volt battery ,placed new
big solenoide ,placed new (the 3 little one,s don,t give trouble saying more dealer tech guy,s)
metal pin behind big solnoide , cleaned flat side,s with sander paper 500 and 1500 till surface was smooth
now pray ,by time .....we now (sofar ok)
greets wilco1v
