Changing laptop - license transfer
waho
Post by waho »
In the near future I plan to buy a new laptop.
Can I transfer my license to another machine without re-purchasing program?
Greets
Re: Changing laptop - license transfer
Yes you can transfer your license.
To do this you use the "Register" button (bottom left corner above F9 Settings button) and follow the instructions on the popup window.
It is always advisable to make a note of your current Hardware Key and License Key and keep them in a safe place. This will allow Multiecuscan support (Yani) to get you back up an running should you forget to deactivate the software before reinstalling or you hit other registration problems.
waho
Post by waho »
So if i understand correctly, first unregister from current laptop and then register on a new one?
Go through the motions when you are ready
The text/instructions I see are: Use Deactivate to generate a removal key and use this key to generate a new license key
Not done it myself but seems fairly straight forward and if all fails then contact Multiecuscan Support.
