Graph all selected Parameters
herliberli
Post by herliberli »
Sorry for my English.
It is Possible to add a Feature that i can Graph and Save all selected Parameters in F4.
Today it´s only possible to Graph and Save 11 selected Parameters.
The Reason is to Save all Parameters in a Long Run and Filter and analyse it later at Home.
Re: Graph all selected Parameters
I've limited the number of parameters becaus the more parameters you select the less refresh rate you get. With 10 selected parameters you get one reading every 4-5 or even more seconds which is not suitable for diagnosis.
It was actually limited to 8 in previous versions. I increased it in the latest version.
herliberli
Hi yani,
i understand your Problem but i think i´ts better to give the User the decision.
By Selection of more then 8 Parameters you can give the User a Information Window for the Refresh Rate.
Or you can do it to the Settings with an information for the Refresh Rate.
My Refresh Rate at 10 selectet Parameters is 2 Seconds.
Tank You
