Multiecuscan 3.1.x Language Files
Posted: 30 Jul 2011, 19:41
by tzok
Polish GUI translation - updated to FES version 3.1.1
P.S.
I have no idea who did the current Polish message file translation but it is totally screwed up, although it has better descriptions for gearbox errors - while English version has only "Gear Ratio (2)" the polish file has "Kontrola przelozenia pierwszego biegu".
I'll try to prepare a new one, based only on current English file.
Re: Multiecuscan 3.1.x Language Files
Posted: 31 Jul 2011, 21:43
by tzok
Does anyone know for sure what does mean the term "a monte"/"a valle" in correlation with O2 Sensor in Italian?
Sonda lambda 1 a monte (massa)
Segnale lambda 2 a monte (sbandata)
Is it above/below catalogue value or it describes the location of the lambda probe - above (before) or below (after) the catalytic converter?
And what are these valves:
Valvola di scarico posteriore SX (Rear left drain valve)
Valvola di carico post.SX (Rear left load valve)
Posted: 02 Aug 2011, 14:41
by tzok
Corrected polish.txt and updated to v.3.1.1 and completely rewritten polish.dat.
Posted: 02 Aug 2011, 17:53
by tzok
Next doubt:
Pressione carburante (regolatore uscita pompa alta pressione o flauto)
Pressione carburante (regolatore ingresso pompa alta Pressione e flauto)
What are they about?
Fuel pressure (regulator output, high pressure pump or ???)
Fuel pressure (regulator input, high pressure pump and ???)
Flauto is the flute but I see no sense...
Next:
Interruttore leva 1
This is sth. about gerbox - Is this Gear 2 selector lever?
Posted: 05 Aug 2011, 20:03
by snorky
Hi wonder if you can also enter the Italian language in the yellow box multiecuscan ... thanks
Posted: 06 Aug 2011, 20:14
by tzok
Content of the "yellow boxes" will remain in English.
Posted: 06 Aug 2011, 21:12
by snorky
You can not do anything for the Italian
Posted: 24 Oct 2011, 14:52
by tzok
FES v.3.3 POLISH DATA
