Just to let you know, that when you'll go to Marelli Body Computer, then to Parameters tab, tick Logistic Mode you're getting incorrect readings.
In my particular case when Low Power is indicated in multiecuscan, car is in Normal mode. When battery icon appears on my dashboard and car is in low power mode, multiecuscan shows that it's in normal mode
In adjustments section everything works fine.
It might be confusing for some users, so letting you all know about it. Have no idea how it works with other cars.
