For some time we discuss about our problems in this topic
viewtopic.php?f=4&t=2095
but that it bears the title of the release 2.8 - it has already decided to set up a new topic under a different name.
since yesterday we have the FES version 3.0.1 with improved stability for VAG KKL, an additional feature test KKL vag and the addition of high latency mode.today for 3 hours I tested it in two cars: Brava 1.2 16v 2000 use (VAG KKL + 3 PIN ADAPTER), and Punto II 1.2 8V FL, 2004.(only VAG KKL)
I checked with all possible settings of parameters in the KWP, LATENCY, ETC use HLM, PORT com settings corect ....
THIS IS THE SAME - Disconnect ME!
Sometimes I was able to read for a few seconds, and sometimes disconnection occurred immediately = Brava
As for the Punto I did some work but with up to two selected parameters, maximum of 5 min and ........... guess what? disconnects.
3 pin adapter or causing loss of signal ?????
I did a test several times VAG KKL and :
VagCom/KKL
Testing latency with 50 bytes of data...
min latency: 1 or 2
max latency : from 2 to .............. 69
every time the test shows different latency ??? it is normal ?
of course, the test took place using laptops: 1.5 to 1.8 Ghz CPU the same as before, the same cables VAG KKL and 3 pin adapter. Of course if it comes to ABS is the same thing !!!!!
READ THE ACTUAL PERFORMANCE = Disconnect
generally I ran out of options ....... or 3 laptops are damaged, 2 x cables KKL vag and a 3 pin connector is also broken, I do not know where the problem is ....... Of course when I plug it into a strong laptop problem disappears....
suggestions, hints, your opinions of those of us at a test ????
