elm327 interface problem
mario nazzareno
Post by mario nazzareno »
Greetings all I am mario from Genoa, Italy :)
I have this problem I connect with elm 327 within various units but not in the injection ecu
talk about panda mjt and punto mjt even gasoline, and so forth, but in the instrument panel or assist enter ok, well, the test interface marks all ok,and "latency too high" ... ... ... ... ... ...
can you help me?
Thank you, :? :?
Teos81
Re: elm327 interface problem
Post by Teos81 »
Ciao,
In che interfacce stai cercando di entrare??
Di solito per quel problema ti basta abbassare il tempo di latenza a 1 dalle proprietà avanzate dalla porta com...
Segui la guida quì
http://www.multiecuscan.net/HowToUse.aspx
ciao
Matteo
Registered 2.8.2 Italian user and EPS specialist
EnIgMa
Post by EnIgMa »
che io sappia l'elm non dovrebbe soffrire di problemi di latenza, dovrebbe essere un problema quasi esclusivo del cavo vag-com...
International: :D
as I know, the latency issue should not belong to elm interfaces...only vag-com cable. Am I right?
mattydr67
Post by mattydr67 »
Yes it is Vag Com issue if you said but look what happend for me:
Same Vag Com kkl interface that I have it and I work with it for a long time.
With previos version like 2.5 or 2.6 it works great, I mean no latency or disconections.
With new softwears from 2.7.2 and newer 2.8.1 or now 2.8.2 it is very instable I mean it's disconacting very easy.
For the newst softwears I suppose that it is not a problem of Vag KKL, I suppose it is a bug of softwear.
I will star a new thread for this to find out if there are many mates who has this kind of issue.
mario nazzareno
thanks for the replies :)
control the latency property of the ports as suggested ...
I speak of ELM327 interface is ok and I tried it with another PC and it works fine
