I decided to purchase FES to perform a Proxi Alignment, as the price of the software was the same as getting an independant diagnostics company to perform it. Anyway long story short the Proxi Alignment failed to execute, heres the log:
CAN CONFIGURATION DATA:
00 00 05 4B 00 00 05 4B 00 00 00 03 00 00 00 01 00 00 00 00
00 00 05 4B 00 00 05 09 00 00 05 4B 00 00 05 09 00 00 05 01
34 36 37 39 33 39 32 34 20 20 20 44 54 53 49 45 45 50 44 45 20 20 00 07 11 4B 05 00 00 09 05 00 00 48 00 00 82 26 07
Body Computer Node (NBC)
Engine Control Node (NCM)
Dashboard Node (NQS)
Brake System Node (NFR)
Driver Door Node (NPG)
Climate Control Node (NCL)
5/8/2011 12:01:41 PM
CONNECTED TO:
ALFA 147 1.6 TS 16V 120CV
Body Computer Node (NBC):
Engine Control Node (NCM):
Dashboard Node (NQS):
Brake System Node (NFR):
Driver Door Node (NPG):
Climate Control Node (NCL):
EXECUTING ADJUSTMENT...
Writing to module: Body Computer Node (NBC)SUCCESS!
Writing to module: Dashboard Node (NQS)FAILED!
Timeout error
Writing to module: Driver Door Node (NPG)SUCCESS!
Writing to module: Climate Control Node (NCL)SUCCESS!
FAILED TO EXECUTE
I assume it's failing because of the timeout error when attempting to write to the Dashboard Node, (if that is the case why does it carry on and write to 2 more nodes?) however, assuming the Dashboard Node is the "clocks" then I have tried the procedure with 2 different sets and the outcome is the same with both. I understand there is problems with the procedure on some cars, the 147 included. Is this just something that needs to be ironed out with software updates? I can wait, I have put up with the flashing for a year now but its really starting to get on my nerves!
Thanks in advance
