Getting disconnected when driving faster than 50 km/h !?
Harleyhos
Post by Harleyhos »
Hi Yani,
I wanted to make a plot while driving. First I thought it simply was a mistake, but after it returned every time.
I am always getting disconnected when I exceed 50km/h.
Is this your SW doing it, or is it the diagnosis port of the Alfa because of safety reasons? -> not safe to drive faster than 50 while ABS and VDC is disabled because of OBD Connection to ABS control unit !?
Thanks a lot!
Doesn't anyone else have this problem?
Regards
Harleyhos
Re: Getting disconnected when driving faster than 50 km/h !?
No, there is no limitation in the software.
It is probably a safety feature of the module which you are connected to.
Which module are you testing? I think that the engine should not disconnect you because of speed restriction, but if you are connecting to the ABS then it is possible.
TribesMan
Post by TribesMan »
Yes this does happen on ABS unit. I noticed that... :)
