Page 1 of 2
Injector Coding NOT WORKING on 159 2.4JTDm
Posted: 01 May 2011, 14:16
by Jerry 159
Yani,
I tryed to code injectors on my 159 2.4JTDm
Its NOT WORKING...
I tryed FES 2.7.1 and also new 2.8 version with:
- KKL interface
- ELM327 1.3
- ELM bluetooth 1.4
I can change the values, and FES says "completed" but when I read the code, its still the same.
The code that I can read with FES is correct for the current injectors, but I cannot change it.
Please help?
Re: Injector Coding NOT WORKING on 159 2.4JTDm
Posted: 01 May 2011, 14:26
by yani
Please, send me a report after failed coding (using the red Send Report button)
Posted: 01 May 2011, 19:30
by Jerry 159
Yani,
Just sended the report to you!
Posted: 01 May 2011, 19:35
by yani
As far as I can see in the report you have used an ELM interface.
There is a problem with the IMA coding function and ELM 327.
Please, try with a KKL interface.
Posted: 02 May 2011, 06:00
by Jerry 159
Hi Yani,
Indeed I was using ELM327 interface.
I have tryed KKL but was getting "Failed to execute" message BUT tryed again and it seems to work, even though I get an error!
I dont mind get the "Failed to execute" message knowing that it works, but maybe you want to fix it? Do I have to send you a report?
Thank you for the Support!
Posted: 02 May 2011, 07:10
by yani
Jerry 159 wrote: Do I have to send you a report?
Yes, please. The report helps me to identify the problem and fix it.
Posted: 02 May 2011, 15:43
by Jerry 159
Yani,
Just sended the report to you.
Posted: 02 May 2011, 19:20
by yani
Thank you very much. I saw where the problem is.
Posted: 13 Jul 2011, 14:33
by maunu
I have also problems with the coding.
I tried to change injector code to 159 2.4JTDm. Everything seems to be fine when programming, but the code does not change. No error messages, just completed message.
I tried several times to change codes but nothing worked. I used FES 3.0.4
Posted: 14 Jul 2011, 14:05
by maunu
I used KKL interface today and everything went fine.
