Your program is not working
cder
Post by cder »
Welcome
Please verify the diagnosis fiat brava 1.4 12v .. FES combined with the ECU, gives the engine, but when you read the error error crashes (links). It does not help the various options with the framework.This issue reported two more board members' Polish Fiat.
error:
The text of the exception Starter
System.IndexOutOfRangeException Index fell outside the boundaries of the array.
at. ? ()
at. (Object, EventArgs)
in System.Windows.Forms.Timer.OnTick (EventArgs e)
in System.Windows.Forms.Timer.TimerNativeWindow.WndProc (Message & m)
in System.Windows.Forms.NativeWindow.Callback (IntPtr hWnd, Int32 msg, IntPtr wParam, IntPtr lparam)
System:
win7 64bit
k-line cable Vagcom OBD II USB Adapter 3pin
Auto:
Fiat Brava 1.4 12V 1996.
ECU:
Bosch injection Monomotronic 1.7.3
multiecuscan 2.7.2 registered.
Pictures:
http://www.fotosik.pl/pokaz_obrazek/94c ... ca219.html
http://www.fotosik.pl/pokaz_obrazek/55d ... 67af7.html
http://www.fotosik.pl/pokaz_obrazek/063 ... 8fb47.html
bubu321
Re: Your program is not working
Post by bubu321 »
pls report : system and used anty-virus.
also in photo pls change language to english, thanks for this.
Ok, I see. Will try to fix the problem in version 2.8 (which will be release this week).
Do you have problem with other modules? Or it is only the Bosch 1.7.3?
Is there anyone else with Bosch 1.7.3 who has the same problem?
cder
Post by cder »
Please, fix this bug in version 2.8.Ten have the same problem two more people besides me.
I noticed this problem only for the Bosch monotronic 1.7.3
Thank you and best regards
kemeu
Post by kemeu »
I have the same problem...
System:
Windows 7 Professiona 32bit
Avast free antivirus
Auto:
Fiat Brava 1.4 12V 1997.
ECU:
yincar
Post by yincar »
yani wrote:Ok, I see. Will try to fix the problem in version 2.8 (which will be release this week).
Yes Yani,
AF 146 98 1.6 TS 16V M1.5.5
AF 146 2.0 TS 16V M2.1
FIAT MAREA 99 100 16V M-M IAW 49F INJ (1.6)
k-l cable Vagcom adapter 3 pin cable not work.
I was try this few car and its was not work .
Thank you .
byrrt
Post by byrrt »
Yani - Does Version 2.8 will be run witch Hitachi MPI?
kemeu
Post by kemeu »
Problem solved with version 2.8.1. ;)
Thanks Yani
