fiat punto 2005 petrol
Posted: 14 Apr 2011, 21:50
by bcas
hello, I'm new with you, I have a fiat punto 1.2 8v 2005, I changed the Body computer with used one and also ECU used, the problem is that the dashboard does not show properly, so I followed your method,to do the procedure alignement, I modified the cable VAG (1 3 7 9) and use the software multiecuscan but this software requires the ELM327, while I do not have that interface, but i have a Mobydic3200 it same interface with ELM327, i modified it (cut pin 7 and switch to 1 3 7 9) the problem the multiecuscan does not recognize Mobydic.
I ask you to help me because I can not buy this interface (ELM327).
if there is solution to change firmware mobydic with firmware ELM327 or forced multiecuscan to work with Mobydic.
thank you for your help and sory for my english (i 've translate french to english by google)
