temperature sensor
piscinarasx
temperature sensor
Post by piscinarasx »
I mounted the external temperature sensor on my puntoevo, now I have to configure the display and 'can do it with the multiecuscan
piscinarasx
Re: temperature sensor
someone can 'help me please? wanted to know if possible with the multiecuscan enable the reporting of temperature on the display already' prepared.
talking puntoevo.
Gianremo
Post by Gianremo »
you must use PROXY Alignment but FES does not support it for Grande Punto/Evo yet. Alternatively you can use Leonardo to active it.
See you.
piscinarasx
thanks so much for the information.
piscinarasx
with version 2.8 will be 'possibile do thank you.
No, unfortunately, the PROXI Alignment function for Punto Evo will not be available in next version.
Also, it seems to me that the PROXI procedure is not enough to activate this sensor. You have to turn ON this option in vehicle configuration, and I don't know how to do it for Punto Evo, yet.
Regards,
piscinarasx
thank you very much
piscinarasx
Hello Yani. say that you can 'do only with the Leonardo may possibly' be able to help to understand.
piscinarasx
activities done by Leonardo.
