Hello Yani.
I replaced my menual with automatic climate control unit in my Stilo 1.6. Will it be ever possible to do Proxi-alignment, that distance (km) on my cluster won't blink?
If you need my log file i can send it to you.
Greetings, Denis
Proxy - replaced menual with automatic A/C climate in Stilo
Re: Proxy - replaced menual with automatic A/C climate in St
Yes, but not yet.denistilo wrote:Will it be ever possible to do Proxi-alignment
BAS
Yes, it will be possible with the next version of Multiecuscan.
Great, thank you for this!
HÍ PEOPLE , HAVE TWO CARS FIAT STILO, IT HAVE ECU DELPHI :
HSFI-2.3 ( ECU ENGINE 1.8 16V year 2008 )
MT27E ( ECU ENGINE 1.8 8V year 2008 )
multiecuscan NOT WORKS WITH MY CAR YET !!!!!!
Hello Yani,
I still have problems with blinking distance (km) on my clousters, becouse of retrofited automatic climate control. I did proxy alignment proceddure but it did't execute succesfully on the one with climate control :
EXECUTING ADJUSTMENT...
PROXI Alignment Procedure
0
0
0
Writing to module: Climate Control Node (NCL) FAILED! - Unknown error
IZVRŠITEV NI USPELA
Unknown error
I also send you a full report of this procedure in the FES. Could you please help mi with this? What is the reason that proxy procedure did't execute?
0
0
0
IZVRŠITEV NI USPELA
Unknown error
Hello yani, still waiting for your answer or instructions to fix this problem with AC
Please send me a report (using the red Send Report buttton) after trying to do PROXI Alignment to your car. And send me a PM with the date/time you sent the report.
I suspect that the change of air conditioner from manual to auto requires some additional modifications to the settings of your car.
