Punto 99 1.2 HLX PROXI
kisza
Post by kisza »
Yani, Please help!!
I just purshade a 2.7.2 version due to odo changed in my fiat i had to get other one due to not showing miles, clock etc on small screen, so i swaped other one from the same model from local scrap yard, the problem what i got is. My car done aprox 77000 miles on the new one is 43000 miles, so when i put new odo miles were flashing and it wasn't showing speed on proper speed i mean im going 40 m/h speedo showing max 20 m/h even when im going 70. in this model speed is coming form ABS sensors so i checked speed in ABS in FES they are okey im going 20m/h speedo showing 5 m/h. I have done Proxi and what happen was that miles stop flashing but still showing 43000 insted 77000 and speedo not working propely!
So i swaped odo back to old one but speed is not showing propely!! and miles are flashing, done proxi again on old one, result miles not flashing and speed not showing propely :shock:
Pleas Help i need speed back on!
Re: Punto 99 1.2 HLX PROXI
I think this can be fixed easily... Probably the new instrument cluster used the gearbox sensor (instead of ABS) and showed incorrect speed because of this. Then this configuration was also transferred to the "old" cluster and it began to show incorrect values as well.
Please send me a PM with the log files of all PROXI alignments.
kisza
Post by kisza »
Yani U R a master thank U the program what u send to me wokerd perfect! apart proxi i did have to use proxi from 2.7.2 version but my problems gone! It was worth to pay 49.99 cheers one more time
