Cables/adapters to use
Timmerklits
Post by Timmerklits »
Maybe it's allready asked here.
I have the normal OBD VAG cable to USB, adapted to do also Airbag and ABS.
Wich cables I do need to do the other diagnoses, and wich one best to buy? (ELM)
Re: Cables/adapters to use
It all depends on what cars you are looking to diagnose.
Please read this page carefully: http://multiecuscan.net/SupportedVehiclesList.aspx
Here you will see what coverage you can get, by vehicle, with KKL/VAG, ELM and OBDKey interfaces.
Do not confuse Interface and cable requirements. These are two completely different things.
Personally I would get KKL AND ELM or OBDKey. You will then be covered for I think everything.
Gendan in the UK (www.gendan.co.uk) do a good ELM interface. Better still they do a ready made cable set that matches the cable connections detailed on the above referenced page.
Hope this helps.
Timmerklits
Thanks for the information.
What about the OBD key?
I see that with that one you can do every module and car?
Or is this one maybe more expensive?
kind Regards,
nick
