CENTRAL LOCKING
Posted: 18 Feb 2011, 18:23
by derekwatt5
HI
does anyone know if this software can diagnose faults with the central locking?? on a fiat stilo!
can you access the information on the ecu to set it up or change it???
any help
thanks
Re: CENTRAL LOCKING
Posted: 18 Feb 2011, 19:09
by yani
Yes, it can.
There are 4 (four) ECUs dealing with the central locking in Stilo - Body Computer ECU, Driver's Door ECU, Passenger Door ECU, Boot ECU ....
Re: CENTRAL LOCKING
Posted: 18 Feb 2011, 19:21
by derekwatt5
what one will deal with the reception from the key fob?? thanks
Re: CENTRAL LOCKING
Posted: 18 Feb 2011, 19:25
by yani
It is the Body Computer.
Re: CENTRAL LOCKING
Posted: 19 Feb 2011, 16:01
by bope
Hi!
I have ALFA 147 1.6 105HP ...the remote key battery is fully charged(3.2V), the led flashing when I push/hold the button...but I cant lock or unlock the doors remotely...I tried to sync the remote with body computer, but when I have to hold a button more than 3sec after that i get message the battery flat...what should I do?
the log:
EXECUTING ADJUSTMENT...
Remote control programming
SECURITY KEY CODE SUCCESS...
COMPLETED
Failed, Battery flat
REMOTE CONTROL DETECTION FAILED...
COMPLETED
Status: UNKNOWN
REMOTE CONTROL STORAGE FAILED...
Re: CENTRAL LOCKING
Posted: 19 Feb 2011, 18:50
by derekwatt5
hi mate
i have the same problem with my stilo! and many others!
pass??????
Re: CENTRAL LOCKING
Posted: 19 Feb 2011, 21:36
by bope
so I found something interesting...
I made PROXI Alignment Procedure and in the log I found this message:
Writing to module: Driver Door Node (NPG)FAILED!
so maybe this driver door node not working correctly, cause "The NPG receives a request to control boot opening via a remote control message or a negative control signal from a button on the central facia control panel." (this info is from ALFA 147 eLEARN cd)
but I'm not 100% sure about this
