Page 1 of 2
SEICENTO SPI 899
Posted: 13 Feb 2011, 21:47
by Darkman
Hi Yani.
At the beginning of FES congratulates the great software that helped me and my friend to the diagnosis Fiat cars .
I would like to ask if there is a possibility that the next version of the FES to handle the engine controller (ECU) Seicento SPI 899 IAW 16F 0.9i and 39hp ( 3 pin conector)
Now FES have Seicento 899 supports, but only ABS and Airbag.
It is very important for my ! ;D In Poland we have a lot of seicento 899 - he maintains a dozen or so. Today, you can diagnose them expensive Tester tech Magneti Marelli equipment type or Launch Diagun X431, or you have an old laptop with two RS232 ports, com (90% is already on the scrap) and buy interface with two ports Euroscan rs232 - is expensive. If you only have to usb port, you must buy Pcmcia card adapter whit 2 x rs232 combo - costs a lot $ ....... , if you already have everything you need to change windows he old DOS system, and can it work? maybe ?
Your program is great, and I think the best group of Italian cars.
Thank you for reading my post - I'm waiting for an answer;)
Greetings, and sorry with my poor English
Thomas from Poland
Re: SEICENTO SPI 899
Posted: 19 Feb 2011, 15:49
by Exodus
Hello Thomas,
look at the free software "startrek punto" for your ECU. Works with KKL and 3 pin fiat adapter fine.
This Software is for all IAW 16F and 6F engine controlers (ECU´s)
Greetings from Germany
Roland
Posted: 19 Feb 2011, 17:19
by Darkman
Vielen Dank Roland .
I already downloaded it:) about a program I was looking for a small seicento -;)
How to hook up? I have cable KKL VAG + 3 pin connector. To connect to the engine ECU, switch to normal position on the ECU pin 7 in interface? MAR ignition on and when I want to then read the parameters of the engine - start the engine? D
My VAG KKL + 3 pin adapter
Conect to Seicento ECU swith to pin 7 ?
I read this text from fiat forum : http://www.fiatforum.com/cinquecento-se ... gging.html
Posted: 22 Feb 2011, 20:57
by Exodus
hook up the 3 Pin Fiat Adapter on ECU
switch kkl kline on pin7
red cable from 3 pin adapter on 12+, no earding need it
start engine
start startrek and drop down... com port + engine
sorry for my bad englisch
Posted: 25 Feb 2011, 15:45
by Darkman
Danke Roland, ich habe alles wie du mir gezeigt, und es funktioniert! ;)
1. Startrek program for punto
2. VAG KKL interface
3. 3 pin adapter cable with the longer +12 V :)
4. Extension for usb cable to sit comfortably in the car when the outside is (-17 degrees) in Poland now ;)
Here a video of this diagnosis seicento. I'm speaking in Polish, but it does not matter - I tell what I do and what I see for the Polish forum.
http://www.youtube.com/watch?v=CyTbeNzx2Rw
program is simple, but given sufficient data in the mode of operation.
Roland I have a question? The first 3 icons on the desktop are active: file, engine, and logging. another 3 did not? errors, active testing, help? whether that be so if the car is everything ok?
Posted: 26 Feb 2011, 06:55
by Exodus
the other three options are available only when the engine light is on or if supported by the engine control unit!
Posted: 26 Feb 2011, 07:52
by Darkman
Hi Roland
Thanks again for your help
If you have any suggestions or access to another program to diagnose 900 SPI to write, be happy to see.
(and sorry my english is bad too.) ;)
Grüße aus dem Polnischen.
Posted: 26 Feb 2011, 16:26
by Exodus
Posted: 26 Feb 2011, 17:35
by Darkman
Yes I know the program but buying 1430zł = + / - 400 euro
dearly & to much ;)
Thanks ;D
Posted: 26 Feb 2011, 18:44
by renter
excuse me, I tried it with a vag-com cable not changed but I could not connect!
Can you tell me if I have to change the cable and how? thanks
