Proxy aligment problem
Posted: 26 Jan 2011, 13:30
by bas
In fiat punto 1.2 8v after dashboard change on a one used from punto 1.2 16V sporting,
proxy aligment process goes ok, but millage is still blinking.
Any idea?
EDIT: report sent 14:43:23 UTC+1
BAS
Re: Proxy aligment problem
Posted: 26 Jan 2011, 16:28
by yani
I saw the log and it seems that the new dashboard does not accept the new configuration. I don't know why...
Do you get correct readings on this dashboard?
I see that it is from vehicle with ABS and it uses the speed signal from the ABS unit. You don't have an ABS and it should not work.
I'm not saying that this causing the problem for not accepting the new configuration.
Posted: 26 Jan 2011, 17:52
by bas
Yes, everything is correct.
BAS
ps. I just translate to the user who does not write in English.
Posted: 07 Mar 2011, 14:23
by Abraa
This might be the same thing like is going on for my Panda. Is that dash you have the highest option (ie. temperature readout, fuel usage etc.)?
