Controlling lights power steering
Posted: 20 Jan 2011, 16:39
by Fidi
Fiat Punto 188, 1.2 8V, first licensing 12/1999
An electric power steering which also functions was inserted afterwards.
The body computer was not exchanged.
Can be activated with multiecuscan and ELM327 the controlling lights for mistake announcement and city mode?
Excuse me, however, I speak no English. The text was translated by machine.
Re: Controlling lights power steering
Posted: 20 Jan 2011, 18:11
by yani
I'm really suprised to hear that there is a Punto Mk2 without electric power steering!
Anyway, you can try the PROXI Alignment Function... but I'm not sure if it will help in your case or not.
Posted: 24 Jan 2011, 10:50
by Fidi
PROXI Alignment Procedure breaks from with mistake.
See the following log file:
CAN CONFIGURATION DATA:
00 00 00 0F 00 00 00 0F 00 00 00 09 00 00 00 00 00 00 00 00 00
00 00 00 0F 00 00 00 09 00 00 00 0F 00 00 00 09 00 00 00 09 00
34 36 37 35 39 32 31 37 20 20 20 30 30 30 30 30 30 30 30 30 30 19 99 03 10 0F 00 00 00 09 00 00 00 05 06 11 03 06 0C 15 00 00 00 00 00
CURRENTLY CONFIGURED CAN MODULES:
Body Computer (NBC)
Motorsteuerung (NCM)
Elektrische Lenkung (NGE)
Instrumententafel (NQS)
CURRENTLY AVAILABLE CAN MODULES:
Body Computer (NBC)
CAN MODULES THAT REQUIRE EOL PROGRAMMING:
Body Computer (NBC)
22.01.2011 16:54:11
CONNECTED TO:
FIAT PUNTO '99 1.2 8V
CURRENTLY CONFIGURED CAN MODULES::
Body Computer (NBC):
Motorsteuerung (NCM):
Elektrische Lenkung (NGE):
Instrumententafel (NQS):
CURRENTLY AVAILABLE CAN MODULES::
CAN MODULES THAT REQUIRE EOL PROGRAMMING::
ACHTUNG!: This vehicle is properly configured. PROXI Alignment is not needed!
EXECUTING ADJUSTMENT...
Prozedur Proxi-Ausrichtung
Writing to module: Body Computer (NBC)SUCCESS!
Writing to module: Instrumententafel (NQS)FAILED!
FEHLER BEIM AUSFÜHREN
Posted: 18 Feb 2011, 16:44
by Fidi
the mistake with the PROXI Alignment procedure is repaired with the release 2.7.
Now both controlling lights of the electric steering system also function.
Many thanks.
