Netbook
Netbook
Does FES work with a netbook that work with windows xp/windows 7 or is necessary to use a notebook? Thank you for the response.
Re: Netbook
Yes fes will work with netbook with windows xp, i use Dellmini 10v with windows xp
and have no problems, hope this helps you
Regards Deano
Regards Deano
Re: Netbook
I have eeepc 900 and use it for testing sometimes. It works without problems.
Make sure that the power profile is NOT set to Max Battery, Power Saver or whatever it is called.
