Injector coding mjet
Posted: 07 Jan 2011, 14:21
by gianni6288
Hy,
I change the injectors on my car, but when i tried to change the ima code in FES with the new code it's doesn't work,it's complete the operation but in the display parameters the injector code doesn't change.My car is AR 147 mjet 16v CF3
Re: Injector coding mjet
Posted: 16 Jan 2011, 19:55
by TribesMan
Yes, injector coding doesen't work on any EDC16 ECU... I have tried it on EDC16C8 and also EDC16C39, but neither worked...
It would be nice if this feature would be fixed...
Posted: 16 Jan 2011, 20:48
by yani
What type of interface did you use?
Posted: 18 Jan 2011, 13:38
by TribesMan
ELM327 v1.3a
I also have KKL interface, but never tried it with KKL, it never came to my mind that it could be an interface type related issue.
Posted: 18 Jan 2011, 16:02
by yani
I'm sure that it was working properly in version 2.2.1. Could be a problem in the latest version...
You can send a report and I will try to find the problem.
Posted: 19 Jan 2011, 14:12
by TribesMan
Never tried it with 2.2.1, I think I tried it with 2.3 and 2.5 but in both cases you got no error message or anything like that. Only when you read the injector codes again the numbers were still the same as before.
Posted: 26 Jan 2011, 00:31
by gianni6288
I tried with 2.2.1 but the result it's the same with elm
Posted: 11 Feb 2011, 11:18
by tomaz100
I have also tried to change injector codes on 147 mjet 16v with elm 327 v1.4 but but codes are the same as before.
Posted: 11 Feb 2011, 18:51
by willow2u
when i recoded injectors on mjet 1.3 punto putting the codes in with elm it would be accepted but they wouldnt change so i used my vagcom lead and even though it came up with failure the codes changed
