Boot Open
bajerko
Boot Open
Post by bajerko »
Hi all,
After I added the cruise control and playing with PROXI Alignment to enable the Cruise Control light on my dashboard I have message BOOT OPEN constantly on.
I also changed ALARM MODE from 0 to 6 and back to 0 but BOOT OPEN message is still there.
FES is working fine, without any error.
Is it just a bug in FES ? Any solution?
P.S. Boot Lid and Bonnet open/close signals are right, so i think the switch should be ok.
Re: Boot Open
What make/model is your car?
I guess it is Alfa 159 from the other posts or it could be Stilo as you say you have enabled the CC light.
So, did you check parameter "Boot open. switch negative"? Does it change when you open/clode the boot.
bajerko
Re: Boot Open
Post by bajerko »
Hi, my car is Stilo JTD.
Here is screen from FES , with some parameters.
When I open/close the BOOT (in the back of my Stilo 3D ) only the BOOT LID parameter in FES is changing to OPEN/CLOSE.
When I open/close the BONNET nothing changed = there is no switch.
